Ir para o conteúdo principal
Asus Q501LA-BBI6T03 Battery Replacement
O que você precisa
  1. Asus Q501LA-BBI6T03 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Battery Replacement: passo 2, imagem 1 %32
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Battery Replacement: passo 3, imagem 1 %32 Asus Q501LA-BBI6T03 Battery Replacement: passo 3, imagem 2 %32
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Battery Replacement, Battery: passo 4, imagem 1 %32
    • Remove the five silver 4mm Phillips #0 screws holding the battery to the laptop.
  5. Asus Q501LA-BBI6T03 Battery Replacement: passo 5, imagem 1 %32
    • Using the spudger, carefully remove the power cable connecting the battery to the rest of the laptop.
  6. Asus Q501LA-BBI6T03 Battery Replacement: passo 6, imagem 1 %32
    • Once the screws and cable are removed, carefully lift the battery from the laptop.
Conclusão
7 outras pessoas executaram este guia.
Kyle Nagao
Membro desde: 01/25/17
366 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-1, Banghart Winter 2017 Membro de Cal Poly, Team 8-1, Banghart Winter 2017
CPSU-BANGHART-W17S8G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 18
Duração total: 5,612
