Ir para o conteúdo principal
Asus Q500A Hard Drive Replacement
O que você precisa
  1. Asus Q500A Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Flip device onto backside
  2. Asus Q500A Hard Drive Replacement: passo 2, imagem 1 %32
    • Use a J0 screwdriver bit to remove both screws on the back-plate, found at the bottom of device.
    • Remove back-plate.
    • Note: Use prying tool if your having issues lifting back-plate.
  3. Asus Q500A Hard Drive Replacement: passo 3, imagem 1 %32 Asus Q500A Hard Drive Replacement: passo 3, imagem 2 %32
    • Remove 4 screws from the metal hard-drive case. There will be one in each corner.
    • Remove the hard-drive case from the device.
  4. Asus Q500A Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the hard-drive. It will be connected to the integrated sata-port in the device.
    • Place hard-drive into slot and connect to the integrated sata port.
    • Place hard drive case back on top of the new hard-drive.
    • Screw in the four screws on the hard-drive case.
  5. Asus Q500A Hard Drive Replacement: passo 6, imagem 1 %32
    • Place back-plate back on device.
    • Screw in the 2 screws on the back of the plate.
Conclusão
cameron
Membro desde: 02/15/17
319 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-5, Eyestone Spring 2017 Membro de USF Tampa, Team 12-5, Eyestone Spring 2017
USFT-EYESTONE-S17S12G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 995
