Ir para o conteúdo principal
Asus Q325U Battery Replacement
O que você precisa
  1. Asus Q325U Battery Replacement, Back Panel: passo 1, imagem 1 %32 Asus Q325U Battery Replacement, Back Panel: passo 1, imagem 2 %32 Asus Q325U Battery Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Battery Replacement: passo 2, imagem 1 %32 Asus Q325U Battery Replacement: passo 2, imagem 2 %32 Asus Q325U Battery Replacement: passo 2, imagem 3 %32
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Battery Replacement, Battery: passo 3, imagem 1 %32 Asus Q325U Battery Replacement, Battery: passo 3, imagem 2 %32
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  4. Asus Q325U Battery Replacement: passo 4, imagem 1 %32 Asus Q325U Battery Replacement: passo 4, imagem 2 %32
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  5. Asus Q325U Battery Replacement: passo 5, imagem 1 %32 Asus Q325U Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery out from the laptop.
Conclusão
4 outras pessoas executaram este guia.
Flo Costa
Membro desde: 01/24/19
235 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S19-G1, White Winter 2019 Membro de Cal Poly, Team S19-G1, White Winter 2019
CPSU-WHITE-W19S19G1
Membros da 3
Autoria de 6 guias
7 comentários
Hello,
Can you point me to a place to purchase a replacement battery? Thanks,
Dan Goldman, daniel.goldman@physics.gatech.edu
Dan Goldman - Responder
Would recommend the screw size be ad to the guide please.
John Walshaw - Responder
Like Dan, I need to get a replacement battery. Any idea where it can be purchased (safely)?
Thanks :D
Michelle N - Responder
not able to get beyond step 4. Any ideas how to open the small screws. I tried PH#000, and many others, but no luck
Steve Kumar - Responder
the battery shown here is not the same for the Q325U, different battery connectors.
Joshua Delgado - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 29
Duração total: 4,437
