Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
Six 9.6 mm screws
Four 4.6 mm screws
Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
Push metal bracket away from battery connector.
Use a spudger to push the battery connection straight up.
Disconnect the Wifi/Bluetooth RF cables from the wireless card.
Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
Pull straight up to disconnect the SATA combo cable from the motherboard.
Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
Two 2.3 mm screws
One 5.6 mm screw
Tilt the drive up slightly by the connector
Remove the SATA combo connector
De-route the SATA and RF cables from the side of the drive bay.
Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
Four 3.7 mm screws
3 outras pessoas executaram este guia.
Um comentário
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
