Ir para o conteúdo principal
Asus Q304UA Hard Drive Replacement
O que você precisa
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: passo 1, imagem 1 %32
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: passo 2, imagem 1 %32 Asus Q304UA Hard Drive Replacement: passo 2, imagem 2 %32 Asus Q304UA Hard Drive Replacement: passo 2, imagem 3 %32
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: passo 3, imagem 1 %32 Asus Q304UA Hard Drive Replacement, Disconnect the battery: passo 3, imagem 2 %32 Asus Q304UA Hard Drive Replacement, Disconnect the battery: passo 3, imagem 3 %32
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: passo 4, imagem 1 %32 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: passo 4, imagem 2 %32 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: passo 4, imagem 3 %32
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: passo 5, imagem 1 %32 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: passo 5, imagem 2 %32
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: passo 6, imagem 1 %32
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: passo 7, imagem 1 %32 Asus Q304UA Hard Drive Replacement: passo 7, imagem 2 %32 Asus Q304UA Hard Drive Replacement: passo 7, imagem 3 %32
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: passo 8, imagem 1 %32 Asus Q304UA Hard Drive Replacement: passo 8, imagem 2 %32
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: passo 9, imagem 1 %32
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: passo 10, imagem 1 %32 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: passo 10, imagem 2 %32
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: passo 11, imagem 1 %32 Asus Q304UA Hard Drive Replacement: passo 11, imagem 2 %32 Asus Q304UA Hard Drive Replacement: passo 11, imagem 3 %32
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: passo 12, imagem 1 %32
    • Remove drive from hard drive bracket.
Conclusão
3 outras pessoas executaram este guia.
iHelpU.Tech
Membro desde: 08/02/17
3.558 Reputação
Autoria de 5 guias
Equipe
iHelpU.tech Membro de iHelpU.tech
Business
Membros da 2
Autoria de 16 guias
Um comentário
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 20
Duração total: 5,121
