Ir para o conteúdo principal
Asus Q200E-CT144H Fan Replacement
O que você precisa
  1. Asus Q200E-CT144H Fan Replacement, Back Cover: passo 1, imagem 1 %32
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Fan Replacement: passo 2, imagem 1 %32
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Fan Replacement: passo 3, imagem 1 %32 Asus Q200E-CT144H Fan Replacement: passo 3, imagem 2 %32
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Fan Replacement, Battery: passo 4, imagem 1 %32 Asus Q200E-CT144H Fan Replacement, Battery: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Fan Replacement: passo 5, imagem 1 %32 Asus Q200E-CT144H Fan Replacement: passo 5, imagem 2 %32
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Fan Replacement: passo 6, imagem 1 %32 Asus Q200E-CT144H Fan Replacement: passo 6, imagem 2 %32
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Fan Replacement, Fan: passo 7, imagem 1 %32
    • Remove the five 4.6mm Phillips #00 screws holding the fan in place.
  8. Asus Q200E-CT144H Fan Replacement: passo 8, imagem 1 %32
    Comprar
    • Disconnect the power bus with tweezers.
  9. Asus Q200E-CT144H Fan Replacement: passo 9, imagem 1 %32
    • Lift and remove the fan from its housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 117
