Ir para o conteúdo principal
Asus Padfone X Mini Docking Port Replacement
O que você precisa
  1. Asus Padfone X Mini Docking Port Replacement, Docking Port: passo 1, imagem 1 %32
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
  2. Asus Padfone X Mini Docking Port Replacement: passo 2, imagem 1 %32
    • Take the battery out of the phone.
  3. Asus Padfone X Mini Docking Port Replacement: passo 3, imagem 1 %32 Asus Padfone X Mini Docking Port Replacement: passo 3, imagem 2 %32
    • Remove the 10 screws around the perimeter of the phone.
    • Remove the cover.
  4. Asus Padfone X Mini Docking Port Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use tweezers to remove the black strip on the left side of the motherboard.
    • The motherboard is the green board on the side with the screen.
    • Be careful not to rip this black strip out of the phone since you will need to reconnect it later. You only need to disconnect it from the mother board.
  5. Asus Padfone X Mini Docking Port Replacement: passo 5, imagem 1 %32
    • Remove the gold flap on the left side of the motherboard.
  6. Asus Padfone X Mini Docking Port Replacement: passo 6, imagem 1 %32
    • Remove the motherboard and replace it.
    • The docking port is connected to your motherboard so you have to get the whole thing replaced if it isn't working.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 45
Ao todo: 402
