Ir para o conteúdo principal
Asus Padfone 2 Battery Replacement
O que você precisa
  1. Asus Padfone 2 Battery Replacement, Power off phone: passo 1, imagem 1 %32
    • Hold down power button to shut off phone.
  2. Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, imagem 1 %32 Asus Padfone 2 Battery Replacement, Remove back cover of phone: passo 2, imagem 2 %32
    • Use plastic opening tool to pry off the back cover of the phone.
  3. Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 1 %32 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 2 %32 Asus Padfone 2 Battery Replacement, Battery Removal: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord
    • Disconnect battery connecting cord using tweezers.
Conclusão
6 outras pessoas executaram este guia.
Zach Standridge
Membro desde: 09/25/14
350 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 5-4, Mcgee Fall 2014 Membro de USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
Membros da 4
Autoria de 7 guias
Um comentário
Pull the battery connector towards USB. You will break it if you pull it up, as I did.
I wouldn’t recommend metal tweezers as it could shortcut the battery.
Los Karlos - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 15
Duração total: 5,901
