Ir para o conteúdo principal
Asus PadFone S Motherboard Replacement
O que você precisa
  1. Asus PadFone S Motherboard Replacement, Remove the Back Panel: passo 1, imagem 1 %32
    • Place your thumb in the charging port and pry the back cover off of the phone.
  2. Asus PadFone S Motherboard Replacement, Remove the Back Panel: passo 2, imagem 1 %32 Asus PadFone S Motherboard Replacement, Remove the Back Panel: passo 2, imagem 2 %32
    • Remove all screws using the T5 Torx screwdriver
    • Lift the back panel off the phone.
  3. Asus PadFone S Motherboard Replacement, Remove the Battery: passo 3, imagem 1 %32 Asus PadFone S Motherboard Replacement, Remove the Battery: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the battery from the logic board using tweezers
    • Using the plastic opening tools, lift the battery up from its slot
    • Apply consistent, steady force to lift the battery from its slot. Be careful not to damage the battery while removing it.
  4. Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: passo 4, imagem 1 %32 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: passo 4, imagem 2 %32 Asus PadFone S Motherboard Replacement, Disconnect the Logic Board: passo 4, imagem 3 %32
    • Disconnect all wires and bands from microphone, SIM card port and side bottons
  5. Asus PadFone S Motherboard Replacement, Remove the Logic Board: passo 5, imagem 1 %32 Asus PadFone S Motherboard Replacement, Remove the Logic Board: passo 5, imagem 2 %32 Asus PadFone S Motherboard Replacement, Remove the Logic Board: passo 5, imagem 3 %32
    • Disconnect remaining band from the logic board
    • Lift the logic board out of the phone
Conclusão
Greg Betsold
Membro desde: 10/23/14
96 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014 Membro de UMass Dartmouth, Team 6-1, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G1
Membros da 3
Autoria de 10 guias
Um comentário
need schematic side button asus padfone s..please send via email kepkep.erwin@gmail.com.
thanks..
kepkep - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 3,602
