Introdução
How to replace broken or not working touchscreen.
WARNING! Work carefully and start only if you are confident you can do it!
O que você precisa
Vídeo de Apresentação
Switch-off the tablet.
By using a plastic tool open the back / battery cover.
There are many clips holding the LCD panel to the metal frame.
Use a spudger to loosen the clips holding the LCD display.
8 outras pessoas executaram este guia.
Um comentário
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
