Ir para o conteúdo principal
Asus Memo Pad ME172V - Touch Screen Replacement
O que você precisa
Vídeo de Apresentação
  1. Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: passo 1, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: passo 1, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement, Touch Screen replacement: passo 1, imagem 3 %32
    • Switch-off the tablet.
    • By using a plastic tool open the back / battery cover.
  2. Asus Memo Pad ME172V - Touch Screen Replacement: passo 2, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 2, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 2, imagem 3 %32
    • Disconnect and remove the battery.
  3. Asus Memo Pad ME172V - Touch Screen Replacement: passo 3, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 3, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 3, imagem 3 %32
    • Disconnect the LCD display flex cable.
    • Disconnect the touchscreen flex cable.
    • Disconnect and remove the loudspeaker.
    • Unscrew 10x screws.
    • Now you can remove the mother board
  4. Asus Memo Pad ME172V - Touch Screen Replacement: passo 4, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 4, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 4, imagem 3 %32
    • Remove the metal LCD display shield.
  5. Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: passo 5, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: passo 5, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement, Separate the LCD panel from the digitizer: passo 5, imagem 3 %32
    • There are many clips holding the LCD panel to the metal frame.
    • Use a spudger to loosen the clips holding the LCD display.
  6. Asus Memo Pad ME172V - Touch Screen Replacement: passo 6, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 6, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 6, imagem 3 %32
    • Heat the touch screen.
    • Use a cutter only to start detachment the touchscreen. Then continue with a plastic tool.
  7. Asus Memo Pad ME172V - Touch Screen Replacement: passo 7, imagem 1 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 7, imagem 2 %32 Asus Memo Pad ME172V - Touch Screen Replacement: passo 7, imagem 3 %32
    • After separation the touchscreen from the front bezel, remove the LCD display frame.
    • This spare part have a double sided adhesive tape. Otherwise you should place.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Conclusão
8 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
192.056 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.525 guias
Um comentário
Is it possible to replace the bezel the way you would an iPad screen instead of going from the back? I feel like a head gun to the front would save you a lot of hassle? Please correct me if I'm wrong
Alex Tucker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 23,513
