Introdução
This guide will show how to replace the battery for the Asus MeMo Pad 10 ME102A
O que você precisa
Insert the blue plastic opening tool into the seam between the back panel and the chassis.
Unplug the blue ribbon cable which runs across the top of the battery near the left-hand speaker. It connects by plugging into a white and black plug on each side. To unplug the ribbon cable, gently pull up the black tabs with the small plastic opening tool.
