Introdução
You will learn how to replace the motherboard. Review this guide if you are having difficulties with the motherboard. In order to replace the motherboard, you have to remove the battery. Please use our Asus MeMO Pad HD 8 ME180A Battery Replacement Guide to do so prior to starting.
O que você precisa
Use a plastic opening tool to separate the back half from the front half.
Pull the back panel away from the device.
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95
Ensure that you are wearing your Anti-Static Wrist Strap.
2 comentários
Où je peux avoir une carte mère pour asus memo pad8 me 180
Shouldn’t there be a step to handle the camera?
