Ir para o conteúdo principal
Asus MeMO Pad HD 8 ME180A Motherboard Replacement
O que você precisa
  1. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: passo 1, imagem 1 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Use a plastic opening tool to separate the back half from the front half.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Be careful not to lose them.
  2. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
  3. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, imagem 1 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, imagem 2 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 3, imagem 3 %32
    • Lift the white bar on the ZIF connector and pull the metal connector out.
  4. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 4, imagem 1 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 4, imagem 2 %32
    • Using your spudger, press down on the two spots shown in order to release the cables.
    • Ensure that the touchscreen cables are fully disconnected.
  5. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 5, imagem 1 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 5, imagem 2 %32
    • Using a PH#0 screwdriver, remove the twelve silver 3.2 mm screws.
    • Pull the battery out.
  6. Asus MeMO Pad HD 8 ME180A Motherboard Replacement, Motherboard: passo 6, imagem 1 %32
    • Disconnect GPS Antenna cable.
  7. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 7, imagem 1 %32
    • Flip the latch and pull the ribbon cable to disconnect the ZIF connector.
  8. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 8, imagem 1 %32
  9. Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 9, imagem 1 %32 Asus MeMO Pad HD 8 ME180A Motherboard Replacement: passo 9, imagem 2 %32
    • Use a PH#0 screwdriver to unscrew the six 3.0 mm black screws.
    • Lift the motherboard straight up to remove.
Conclusão
Equipe
USF Tampa, Team 2-5, Nance Fall 2016 Membro de USF Tampa, Team 2-5, Nance Fall 2016
USFT-NANCE-F16S2G5
Membros da 3
Autoria de 10 guias
2 comentários
Où je peux avoir une carte mère pour asus memo pad8 me 180
David Leblanc - Responder
Shouldn’t there be a step to handle the camera?
Haggai Eran - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 748
