Introdução
This guide will direct you in replacing the entire speaker assembly for the tablet. The guide will require a few simple steps and removing a few small screws form the device.
O que você precisa
Passo 1 Remove Rear Panel
Cuidado: as etapas de 1 a 4 são provenientes de um guia marcado como em andamento.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Unscrew two Philip's #000 2 mm screws located on the left and right side of the speaker housing.
3 outras pessoas executaram este guia.
