Introdução
This guide will step you through replacing the GPS Antenna on your Asus Tablet. This process is straight forward and should not be too difficult.
O que você precisa
Passo 1 Remove Rear Panel
Cuidado: as etapas de 1 a 4 são provenientes de um guia marcado como em andamento.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the motherboard.
