Introdução
This guide is to show you how to replace the battery in an Asus MeMO Pad HD 7. This is a simple procedure that can be accomplished by anyone.
O que você precisa
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
I don't think you need to do this step (my motherboard came out and back in just fine, I just had to keep the battery cord out of the way, which is way easier than prying the whole thing out of there).
14 outras pessoas executaram este guia.
4 comentários
How did you fix the sd card port?
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
Important: Remove SD card first!
Ola Eldøy - Responder
