Ir para o conteúdo principal
Asus MeMO Pad HD 7 Battery Replacement
O que você precisa
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, imagem 1 %32 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, imagem 2 %32 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: passo 1, imagem 3 %32
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Battery Replacement: passo 2, imagem 1 %32
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: passo 3, imagem 1 %32
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, imagem 1 %32 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, imagem 2 %32 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: passo 4, imagem 3 %32
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
Conclusão
14 outras pessoas executaram este guia.
Julien Daigle
Membro desde: 01/20/15
1.235 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-3, Blackwell Winter 2015 Membro de USF Tampa, Team 11-3, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G3
Membros da 4
Autoria de 5 guias
4 comentários
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - Responder
How did you fix the sd card port?
yanisstavrou - Responder
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - Responder
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 21,969
