Ir para o conteúdo principal
Asus MeMO Pad 7 ME176C Speaker Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    iFixit Opening Tool
    $1.99
    Comprar
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 2, imagem 2 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 2, imagem 3 %32
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 3, imagem 2 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 3, imagem 3 %32
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: passo 4, imagem 1 %32
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: passo 5, imagem 1 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 5, imagem 2 %32 Asus MeMO Pad 7 ME176C Speaker Replacement: passo 5, imagem 3 %32
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: passo 6, imagem 1 %32
    • Now you can attach a new speaker!
Conclusão
Maxime
Membro desde: 09/26/17
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S6-G3, Banghart Fall 2017 Membro de Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 227
