Ir para o conteúdo principal
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: passo 1, imagem 2 %32
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 2, imagem 2 %32
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 3, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 4, imagem 1 %32
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 5, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 5, imagem 2 %32
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 6, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 6, imagem 2 %32
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 7, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 7, imagem 2 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 7, imagem 3 %32
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 8, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 8, imagem 2 %32
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 9, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 9, imagem 2 %32
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 10, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 10, imagem 2 %32
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 11, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 11, imagem 2 %32
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 12, imagem 1 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 12, imagem 2 %32 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: passo 12, imagem 3 %32
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
Conclusão
Nejad Harara
Membro desde: 09/26/17
110 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S6-G3, Banghart Fall 2017 Membro de Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
Membros da 5
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 1,692
