Ir para o conteúdo principal
Asus MeMO Pad 7 ME176C Battery Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME176C Battery Replacement, Battery Replacement: passo 1, imagem 1 %32
    • Make sure the device is turned off.
    • Use a plastic opening tool to remove the back panel by carefully moving the tool around the back cover of the device until it comes off.
  2. Asus MeMO Pad 7 ME176C Battery Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME176C Battery Replacement: passo 2, imagem 2 %32
    • Locate the black bundle connector on the back of the device. Gently slide the plastic tool underneath the black bundle cable connector towards the battery until it comes off.
  3. Asus MeMO Pad 7 ME176C Battery Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME176C Battery Replacement: passo 3, imagem 2 %32 Asus MeMO Pad 7 ME176C Battery Replacement: passo 3, imagem 3 %32
    • Using the plastic opener tool, carefully remove the ZIF connectors that is covering the battery.
  4. Asus MeMO Pad 7 ME176C Battery Replacement: passo 4, imagem 1 %32 Asus MeMO Pad 7 ME176C Battery Replacement: passo 4, imagem 2 %32 Asus MeMO Pad 7 ME176C Battery Replacement: passo 4, imagem 3 %32
    • Wedge the flat end of a spudger or plastic opening tool under the battery to free the battery form any adhesives.
    • Do not bend or puncture the battery.
Conclusão
3 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S6-G3, Banghart Fall 2017 Membro de Cal Poly, Team S6-G3, Banghart Fall 2017
CPSU-BANGHART-F17S6G3
Membros da 5
Autoria de 9 guias
Um comentário
It might be better to remove the whole aluminum tray under the battery. It is really tough to slice the tape holding the battery to the tray without bending up the battery or putting a lot of pressure on the circuit board. It looks like nine screws and a couple extra steps.
Jim80686 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Duração total: 2,204
