Ir para o conteúdo principal
Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: passo 1, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Motherboard: passo 1, imagem 3 %32
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 2, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 2, imagem 3 %32
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 3, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 4, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 4, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 4, imagem 3 %32
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 5, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 5, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 6, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 6, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 6, imagem 3 %32
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 7, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 7, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 8, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 8, imagem 2 %32
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 9, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 9, imagem 2 %32
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 10, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 10, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 10, imagem 3 %32
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 11, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 11, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 11, imagem 3 %32
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 12, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 12, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 12, imagem 3 %32
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 13, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement: passo 13, imagem 2 %32
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
  14. Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: passo 14, imagem 1 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: passo 14, imagem 2 %32 Asus MeMO Pad 7 ME170C Rear Facing Camera Replacement, Rear Facing Camera: passo 14, imagem 3 %32
    • Gently remove grey tape that is holding down connector for camera using the tweezers.
    • When tape is removed, use the plastic prying tool to gently unlock connector between camera wiring and motherboard. The connector lock rotates upward away from motherboard to release.
    • Carefully remove camera from motherboard using tweezers by pulling directly upward. Camera should release easily without much resistance.
Conclusão
Thomas Brooks
Membro desde: 03/04/17
301 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S3-G3, Wilson Spring 2017 Membro de IUPUI, Team S3-G3, Wilson Spring 2017
IUPUI-WILSON-S17S3G3
5 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 154
