Ir para o conteúdo principal
Asus MeMO Pad 7 ME170C Microphone Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: passo 1, imagem 2 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement, Microphone: passo 1, imagem 3 %32
    • Before beginning to dissemble, power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Using the Jimmy tool, gently wedge it into the seam of the device.
    • Gently pry the Jimmy tool all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 2, imagem 2 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 2, imagem 3 %32
    • Inserted in a black port on the motherboard, locate the white cable connector on the left side of the tablet.
    • In a side to side motion, using the smallest opening tool, slide the white cable box completely out of the port towards the bottom of the device.
  3. Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 3, imagem 2 %32
    • Pull the wire out of its tracking panel gently.
    • Note: This wire should be fairly easy to pull out of the panel.
  4. Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 4, imagem 1 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 4, imagem 2 %32 Asus MeMO Pad 7 ME170C  Microphone  Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Note: The end of the wire is attached to a small taped black box.
    • Using wide nosed tweezers, lift up the tape and remove from black box.
    • Note: Black box will loosen up once the tape is removed.
    • Remove the component completely from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 1,027
