Ir para o conteúdo principal
Asus MeMO Pad 7 ME170C Battery Replacement
O que você precisa
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, imagem 1 %32 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, imagem 2 %32 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: passo 1, imagem 3 %32
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, imagem 1 %32 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, imagem 2 %32 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 2, imagem 3 %32
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, imagem 1 %32 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, imagem 2 %32 Asus MeMO Pad 7 ME170C  Battery Replacement: passo 3, imagem 3 %32
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 3,097
