Introdução
This guide will show you how to replace a battery for a Asus MeMO Pad 7. The battery replacement is a simple procedure. If the battery is dead, the replacement could help your tablet to turn on.
O que você precisa
Make sure your device is turned off. Then with a plastic opening tool, carefully remove the back panel by carefully working your way around the perimeter.
4 outras pessoas executaram este guia.
Um comentário
But whats the secret to cleaning off the glue and resealing it?
