Introdução
The Asus K55A-Si50301P Hard Drive Replacement Guide explains the tools and process used to replace/remove the Hard Drive as needed. The hard drive may occur to be damaged/faulty when general hardware such as screws become loose and release the drive from its connection. The Asus K55A-Si50301P Troubleshooting page may be referred to hereas needed.
O que você precisa
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
4 outras pessoas executaram este guia.
