Ir para o conteúdo principal
Asus K55VD Fan Replacement
O que você precisa
  1. Cuidado: a etapa 1 é proveniente de um guia marcado como em andamento.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD Fan Replacement, Hard Drive: passo 2, imagem 1 %32 Asus K55VD Fan Replacement, Hard Drive: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 1.5 mm screws in the smaller portion of the bottom cover.
    • After removing the screws, remove the smaller cover.
  3. Asus K55VD Fan Replacement: passo 3, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the 1.5 mm screws that hold down the hard drive.
  4. Asus K55VD Fan Replacement: passo 4, imagem 1 %32 Asus K55VD Fan Replacement: passo 4, imagem 2 %32
    • Remove the hard drive from the slot.
    • Remove the hard drive from its shell.
  5. Asus K55VD Fan Replacement, Fan: passo 5, imagem 1 %32 Asus K55VD Fan Replacement, Fan: passo 5, imagem 2 %32 Asus K55VD Fan Replacement, Fan: passo 5, imagem 3 %32
    • Remove all 12 screws from the bottom cover with a Phillips #0 screwdriver.
    • The four screws nearest the display hinges are longer.
    • The single screw in the middle of the bottom cover is shorter than the rest.
  6. Asus K55VD Fan Replacement: passo 6, imagem 1 %32 Asus K55VD Fan Replacement: passo 6, imagem 2 %32 Asus K55VD Fan Replacement: passo 6, imagem 3 %32
    • After the screws are removed, Orientate the device so that the keyboard is shown.
    • Using the Plastic Pry tool separate the keyboard panel from the rest of the laptop.
  7. Asus K55VD Fan Replacement: passo 7, imagem 1 %32 Asus K55VD Fan Replacement: passo 7, imagem 2 %32
    • Before the keyboard panel can be fully removed, detach the three cords that connect to the keyboard.
    • Lift up on the black tab and the cord will fall out.
  8. Asus K55VD Fan Replacement: passo 8, imagem 1 %32 Asus K55VD Fan Replacement: passo 8, imagem 2 %32 Asus K55VD Fan Replacement: passo 8, imagem 3 %32
    • Remove the optical dive by sliding it outward.
  9. Asus K55VD Fan Replacement: passo 9, imagem 1 %32 Asus K55VD Fan Replacement: passo 9, imagem 2 %32 Asus K55VD Fan Replacement: passo 9, imagem 3 %32
    • Now remove the two wires shown by pulling away from the motherboard.
  10. Asus K55VD Fan Replacement: passo 10, imagem 1 %32 Asus K55VD Fan Replacement: passo 10, imagem 2 %32 Asus K55VD Fan Replacement: passo 10, imagem 3 %32
    • Remove the three screws holding the motherboard and fan in place using the Phillips #0 bit.
    • The top left screw shown in the first picture is easily broken
  11. Asus K55VD Fan Replacement: passo 11, imagem 1 %32 Asus K55VD Fan Replacement: passo 11, imagem 2 %32 Asus K55VD Fan Replacement: passo 11, imagem 3 %32
    • lift up on the entire motherboard and unplug the bottom wires connected to the fan.
  12. Asus K55VD Fan Replacement: passo 12, imagem 1 %32 Asus K55VD Fan Replacement: passo 12, imagem 2 %32
    • After all cords have been removed, the fan can be removed as well.
Conclusão
7 outras pessoas executaram este guia.
2 comentários
At step 5, you should also unscrew the bottom silver screw and unplug the wifi antennas.
https://i.imgur.com/vRrlRkv.png
Daniel - Responder
At step 3, the bottom left screw does not hold down the drive bay. Unsrew that screw in step 5.
Daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 2,694
