Ir para o conteúdo principal
Asus K55N-DS81 Rear Panel Replacement
O que você precisa
  1. Asus K55N-DS81 Rear Panel Replacement, Battery: passo 1, imagem 1 %32
    • Flip the laptop over, such that the bottom of the laptop is facing upwards.
    • Ensure that the laptop is powered off prior to following this guide.
  2. Asus K55N-DS81 Rear Panel Replacement: passo 2, imagem 1 %32 Asus K55N-DS81 Rear Panel Replacement: passo 2, imagem 2 %32
    • Pull the latch to the right of the battery to the right.
  3. Asus K55N-DS81 Rear Panel Replacement: passo 3, imagem 1 %32 Asus K55N-DS81 Rear Panel Replacement: passo 3, imagem 2 %32
    • Pull the latch to the left of the battery to the left. Hold the latch open with a finger to prevent it from closing.
  4. Asus K55N-DS81 Rear Panel Replacement: passo 4, imagem 1 %32 Asus K55N-DS81 Rear Panel Replacement: passo 4, imagem 2 %32
    • While holding the second latch from the previous step, use another hand to reach underneath the battery.
    • Pull the battery upwards and away from the laptop to remove it.
  5. Asus K55N-DS81 Rear Panel Replacement, Rear Panel: passo 5, imagem 1 %32 Asus K55N-DS81 Rear Panel Replacement, Rear Panel: passo 5, imagem 2 %32
    • Using a JIS #00 screwdriver, unscrew the two 5 mm screws on either side of the laptop panel.
  6. Asus K55N-DS81 Rear Panel Replacement: passo 6, imagem 1 %32 Asus K55N-DS81 Rear Panel Replacement: passo 6, imagem 2 %32 Asus K55N-DS81 Rear Panel Replacement: passo 6, imagem 3 %32
    • Remove the panel by pushing away from the laptop until the panel is free of the laptop.
    • Lift to remove the panel.
Conclusão
Uma outra pessoa concluiu este guia.
Elliott Beckner
Membro desde: 11/05/18
543 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S2-G1, Baechle Fall 2018 Membro de IUPUI, Team S2-G1, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 362
