Introdução
Over time, your laptop's optical drive may fail to read discs due as a result of being used excessively. You will be able to replace your failing optical drive with the help of a Phillips #0 screwdriver and a prying tool.
O que você precisa
Push the two locking mechanisms at the top of your laptop away from each other.
Pull the battery away from your laptop using your hands.
Flip the laptop over and open the lid to reveal the keyboard.
Insert the blue prying tool into each of the five tabs located at the top of the keyboard, pulling upwards on the keyboard to separate it from the palm rest.
Once the top of the keyboard has been separated from the device, slowly begin pulling the keyboard away from the laptop using your hands.
