Ir para o conteúdo principal
Asus K53E-BBR7 Keyboard Replacement
O que você precisa
  1. Asus K53E-BBR7 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Asus K53E-BBR7 Keyboard Replacement, Keyboard: passo 1, imagem 2 %32 Asus K53E-BBR7 Keyboard Replacement, Keyboard: passo 1, imagem 3 %32
    • Turn off the device.
    • Disconnect the charging cable if applicable.
    • Push the two locking mechanisms away from the center of the device and slowly remove the battery.
  2. Asus K53E-BBR7 Keyboard Replacement: passo 2, imagem 1 %32 Asus K53E-BBR7 Keyboard Replacement: passo 2, imagem 2 %32 Asus K53E-BBR7 Keyboard Replacement: passo 2, imagem 3 %32
    • Insert the blue prying tool into each of the five tabs at the top of your keyboard, moving from the outer edge inward. Use the blue prying tool to separate the keyboard from the palm rest.
    • Use your hand to gently pull the keyboard away from the laptop.
  3. Asus K53E-BBR7 Keyboard Replacement: passo 3, imagem 1 %32 Asus K53E-BBR7 Keyboard Replacement: passo 3, imagem 2 %32
    • As the keyboard comes loose, gently lift the board up so the bottom is exposed
    • The base of the keyboard will be tethered to the device by a piece of silver cable ribbon. Tearing this piece away from the keyboard quickly can damage the device.
    • Use your fingers to gently disconnect the silver cable ribbon from the palm rest.
Conclusão
4 outras pessoas executaram este guia.
Graham Rumbaugh
Membro desde: 10/28/16
173 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-3, Rose Fall 2016 Membro de UW Tacoma, Team 1-3, Rose Fall 2016
UWT-ROSE-F16S1G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 1,447
