Ir para o conteúdo principal
Asus K53E-BBR3 Keyboard Replacement
O que você precisa
  1. Asus K53E-BBR3 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Asus K53E-BBR3 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Asus K53E-BBR3 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Asus K53E-BBR3 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32 Asus K53E-BBR3 Keyboard Replacement, Keyboard: passo 2, imagem 3 %32
    • There is a ribbon connector underneath the keyboard. When lifting up the keyboard be gentle and carefully it up.
    • Insert the spudger into the indent near the "ESC" key.
    • Firmly wiggle the spudger across the keyboard in between the space until you can remove the keyboard.
  3. Asus K53E-BBR3 Keyboard Replacement: passo 3, imagem 1 %32
    • Gently pull the ribbon cable to the right and out of its port.
Conclusão
Liza Sousa
Membro desde: 10/17/16
355 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-1, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 760
