Ir para o conteúdo principal
Asus K53E-BBR3 Hard Drive Replacement
O que você precisa
  1. Asus K53E-BBR3 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Asus K53E-BBR3 Hard Drive Replacement, Battery: passo 1, imagem 2 %32 Asus K53E-BBR3 Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Place your laptop face down in front of you.
    • Slide the button in the top right corner to the right so that the orange marker is showing.
    • Press the spring loaded latch to release the battery from the computer.
  2. Asus K53E-BBR3 Hard Drive Replacement, Back Panel: passo 2, imagem 1 %32
    • Unscrew two 5mm Phillips #1 screws.
  3. Asus K53E-BBR3 Hard Drive Replacement: passo 3, imagem 1 %32
    • Pull down and lift up on the back panel to remove it.
  4. Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32 Asus K53E-BBR3 Hard Drive Replacement, Hard Drive: passo 4, imagem 3 %32
    • Unscrew the four 5mm Phillips #1 screws.
    • Lift the hard drive out of the computer.
  5. Asus K53E-BBR3 Hard Drive Replacement: passo 5, imagem 1 %32 Asus K53E-BBR3 Hard Drive Replacement: passo 5, imagem 2 %32
    • Unscrew the screws on the hard drive case.
    • Two 3mm Phillips #1 screws are located on one edge of the case.
    • The last two 3mm #1 Phillips screws are located on the opposite side of the case.
    • After you unscrew all four screws, the metal cage will fall off, leaving you with the hard drive.
Conclusão
Jacob O'Donnell
Membro desde: 10/17/16
323 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 1-1, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-1, Catania Fall 2016
UMASSD-CATANIA-F16S1G1
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 1,744
