Introdução
Fans can overheat and stop working. This guide will help you be able to remove and replace the fan inside the ASUS K50IJ.
O que você precisa
Slide the tab over to unlock the battery cover located on the bottom-left corner of the laptop.
Using the PH1 screwdriver, remove the four 4 .75 mm screws that are located on the vent panel.
Uma outra pessoa concluiu este guia.
