Ir para o conteúdo principal
Asus GL551JW-AH71 RAM Replacement
O que você precisa
  1. Asus GL551JW-AH71 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 RAM Replacement: passo 2, imagem 1 %32 Asus GL551JW-AH71 RAM Replacement: passo 2, imagem 2 %32
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 RAM Replacement: passo 3, imagem 1 %32 Asus GL551JW-AH71 RAM Replacement: passo 3, imagem 2 %32
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 RAM Replacement, RAM: passo 4, imagem 1 %32 Asus GL551JW-AH71 RAM Replacement, RAM: passo 4, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the two 11mm screws that hold the access panel in place.
  5. Asus GL551JW-AH71 RAM Replacement: passo 5, imagem 1 %32
    • Remove the access panel by lifting it up.
  6. Asus GL551JW-AH71 RAM Replacement: passo 6, imagem 1 %32 Asus GL551JW-AH71 RAM Replacement: passo 6, imagem 2 %32 Asus GL551JW-AH71 RAM Replacement: passo 6, imagem 3 %32
    • Locate the tabs holding the RAM chip in place.
    • Push the tabs in an outward direction from the RAM and the RAM will be released.
    • Gently remove the RAM from the motherboard.
Conclusão
William Kelley
Membro desde: 03/20/19
1.035 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 242
