Ir para o conteúdo principal
Asus GL551JW-AH71 Hard Drive Replacement
O que você precisa
  1. Asus GL551JW-AH71 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Hard Drive Replacement: passo 2, imagem 1 %32 Asus GL551JW-AH71 Hard Drive Replacement: passo 2, imagem 2 %32
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Hard Drive Replacement: passo 3, imagem 1 %32 Asus GL551JW-AH71 Hard Drive Replacement: passo 3, imagem 2 %32
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32 Asus GL551JW-AH71 Hard Drive Replacement, Hard Drive: passo 4, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the two 16 mm screws on the access panel.
  5. Asus GL551JW-AH71 Hard Drive Replacement: passo 5, imagem 1 %32
    • Remove the access panel by lifting it up.
  6. Asus GL551JW-AH71 Hard Drive Replacement: passo 6, imagem 1 %32 Asus GL551JW-AH71 Hard Drive Replacement: passo 6, imagem 2 %32
    • Using the Phillips #000 screwdriver, remove the four screws holding the hard drive in place.
    • The pictures in this step do not contain a a hard drive. The location where the hard drive would be located is indicated by the orange rectangle.
  7. Asus GL551JW-AH71 Hard Drive Replacement: passo 7, imagem 1 %32
    • Pull out hard drive.
Conclusão
William Kelley
Membro desde: 03/20/19
1.035 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 277
