Introdução
This guide outlines how to replace the fan in the Asus GL551JW-AH71.
O que você precisa
Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
3 outras pessoas executaram este guia.
