Ir para o conteúdo principal
Asus GL551JW-AH71 Fan Replacement
O que você precisa
  1. Asus GL551JW-AH71 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Fan Replacement: passo 2, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 2, imagem 2 %32
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Fan Replacement: passo 3, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 3, imagem 2 %32
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Fan Replacement, Optical Drive: passo 4, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement, Optical Drive: passo 4, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Fan Replacement: passo 5, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 5, imagem 2 %32 Asus GL551JW-AH71 Fan Replacement: passo 5, imagem 3 %32
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Fan Replacement: passo 6, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 6, imagem 2 %32
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Fan Replacement, Upper Assembly: passo 7, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement, Upper Assembly: passo 7, imagem 2 %32
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Fan Replacement: passo 8, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 8, imagem 2 %32
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Fan Replacement: passo 9, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 9, imagem 2 %32
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Fan Replacement: passo 10, imagem 1 %32
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Fan Replacement: passo 11, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 11, imagem 2 %32 Asus GL551JW-AH71 Fan Replacement: passo 11, imagem 3 %32
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Fan Replacement: passo 12, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 12, imagem 2 %32 Asus GL551JW-AH71 Fan Replacement: passo 12, imagem 3 %32
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
  13. Asus GL551JW-AH71 Fan Replacement, Fan: passo 13, imagem 1 %32
    • Place the separated motherboard keyboard side down.
  14. Asus GL551JW-AH71 Fan Replacement: passo 14, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 14, imagem 2 %32 Asus GL551JW-AH71 Fan Replacement: passo 14, imagem 3 %32
    • Unplug the fan connector cable from the motherboard with an iFixit opening tool.
  15. Asus GL551JW-AH71 Fan Replacement: passo 15, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 15, imagem 2 %32
    • With a Phillips #00 screwdriver, remove the three 5mm screws that hold the fan in place.
  16. Asus GL551JW-AH71 Fan Replacement: passo 16, imagem 1 %32 Asus GL551JW-AH71 Fan Replacement: passo 16, imagem 2 %32
    • Gently remove the fan from the motherboard.
Conclusão
3 outras pessoas executaram este guia.
William Kelley
Membro desde: 03/20/19
1.035 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team S8-G3, Bailey Spring 2019 Membro de UMass Dartmouth, Team S8-G3, Bailey Spring 2019
UMASSD-BAILEY-S19S8G3
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 33
Duração total: 1,523
