Ir para o conteúdo principal
Asus G75VW-BHI7N07 Trackpad Buttons Replacement
O que você precisa
  1. Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: passo 1, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: passo 1, imagem 2 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement, Trackpad Buttons: passo 1, imagem 3 %32
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 2, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 2, imagem 2 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 2, imagem 3 %32
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 3, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 3, imagem 2 %32
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 4, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 4, imagem 2 %32
    • Take off the henge cover using the opening tool.
    • Remove the 2 black outside edge (9 mm) screws with the J0 Phillips screwdriver.
  5. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 5, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 5, imagem 2 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 5, imagem 3 %32
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands.
    • Remove all electrical connections using your hands.
  6. Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 6, imagem 1 %32 Asus G75VW-BHI7N07 Trackpad Buttons Replacement: passo 6, imagem 2 %32
    • Take the 2 (3 mm) screws out of the trackpad using the PH1 Phillips screwdriver.
    • Remove the trackpad buttons using your hands.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 1,336
