Ir para o conteúdo principal
Asus G75VW-BHI7N07 Optical Drive Assembly Replacement
O que você precisa
  1. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: passo 1, imagem 1 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: passo 1, imagem 2 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement, Optical Drive: passo 1, imagem 3 %32
    • If you have power, press the eject button.
    • If you don't have power, use the opening tool to pry off the disk drive cover.
    • Press the Manual Eject button with the spudger and the disk drive should slide out. (Might need tweezers if it doesn't pop out immediately)
    • Once the disc drive pops out, flip the laptop over.
  2. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 2, imagem 1 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 2, imagem 2 %32
    • Remove the 4 screws that hold down the metal plate with the J0 Phillips-head screwdriver.
    • Put the screws onto the magnetic pad, to avoid losing any.
    • Lift the metal plate off the optical drive with your fingers.
  3. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 3, imagem 1 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 3, imagem 2 %32
    • Remove 3 screws of disc drive with the J0 Phillips-head screwdriver.
    • Pick up the disc drive assembly and pull it out.
  4. Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 4, imagem 1 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 4, imagem 2 %32 Asus G75VW-BHI7N07 Optical Drive Assembly Replacement: passo 4, imagem 3 %32
    • Remove optical assembly by hand.
    • Remove disc reader by removing 2 bolts from the top using the J0 Phillips-head screwdriver.
    • Lift the metal piece out.
    • Make sure no edges are sticking out when putting the metal plate back in place.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 783
