Ir para o conteúdo principal
Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement
O que você precisa
  1. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Battery: passo 1, imagem 1 %32
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 2, imagem 1 %32
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 3, imagem 1 %32
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: passo 4, imagem 1 %32 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement, Left and Right Speaker Bar: passo 4, imagem 2 %32
    • Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
    • Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
  5. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 5, imagem 1 %32
    • Carefully turn the laptop right-side up.
    • Using an opening tool, pry the outer edges of the hinge cover up and away from the laptop.
    • The hinge cover, located at the back of the laptop, is the long plastic plate that covers the hinges and speakers.
  6. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 6, imagem 1 %32 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 6, imagem 2 %32 Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 6, imagem 3 %32
    • Without disconnecting the speaker cable, set the hinge cover upside-down.
    • Hold the speaker cable by its white connector, then pull to unplug it from the motherboard.
    • You may need to apply some force, as these connectors can be difficult to unplug.
  7. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 7, imagem 1 %32
    • The speaker is attached to the hinge cover by four 3.5mm Phillips #00 screws. Unscrew and remove them.
  8. Asus G750JW-BBI7N05 Left and Right Speaker Bar Replacement: passo 8, imagem 1 %32
    • Lift the speaker to remove it.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 721
