Introdução
The left and right speaker bar is located underneath the hinge cover at the back of the laptop. Follow the steps in this guide to replace it.
O que você precisa
Remove the rubber stoppers in the top left and right corners to expose two 9mm Phillips #00 screws. Unscrew and remove them.
Unscrew and remove the three 4mm Phillips #00 screws inside the battery compartment.
3 outras pessoas executaram este guia.
