Ir para o conteúdo principal
Asus G74SX-BBK7 Trackpad Button Replacement
O que você precisa
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: passo 1, imagem 1 %32
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: passo 2, imagem 1 %32
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: passo 3, imagem 1 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 3, imagem 2 %32
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: passo 4, imagem 1 %32
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: passo 5, imagem 1 %32
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: passo 6, imagem 1 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 6, imagem 2 %32
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, imagem 1 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, imagem 2 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 7, imagem 3 %32
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: passo 8, imagem 1 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 8, imagem 2 %32
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, imagem 1 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, imagem 2 %32 Asus G74SX-BBK7 Trackpad Button Replacement: passo 9, imagem 3 %32
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Conclusão
Ryan Lawrence
Membro desde: 04/14/15
611 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-10, Maness Spring 2015 Membro de Cal Poly, Team 5-10, Maness Spring 2015
CPSU-MANESS-S15S5G10
Membros da 4
Autoria de 6 guias
Um comentário
Where did you find the part?
websmiths - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 21
Duração total: 4,809
