Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
Take off the back panel.
Ferramenta utilizada nesse passo:Anti-Static Wrist Strap$7.95-
Locate the RAM near the center of the computer.
Push gently on the metal pins that are on both sides of the RAM sticks.
When you push on the pins, the RAM will pop up. Gently remove it from its socket.
Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
