Ir para o conteúdo principal
Asus G73JH-RBBX05 Fan Replacement
O que você precisa
  1. Asus G73JH-RBBX05 Fan Replacement, Keyboard: passo 1, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement, Keyboard: passo 1, imagem 2 %32
    • Locate the 5 clips located at the top of the keyboard. Insert a metal spudger into the clip openings on the keyboard to remove the keyboard.
  2. Asus G73JH-RBBX05 Fan Replacement: passo 2, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement: passo 2, imagem 2 %32 Asus G73JH-RBBX05 Fan Replacement: passo 2, imagem 3 %32
    • Before fully removing the keyboard, remove the back lighting cable and keyboard data strip.
    • In order to remove these cables, push forward the black retention clips and pull out the cables.
  3. Asus G73JH-RBBX05 Fan Replacement, Fan: passo 3, imagem 1 %32
    • Remove the 4mm screws located under the keyboard with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Fan Replacement: passo 4, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement: passo 4, imagem 2 %32
    • Using a PH0 screwdriver, remove the two, 4mm screws .
    • Using either your finger or a plastic opening tool, remove the back panel.
  5. Asus G73JH-RBBX05 Fan Replacement: passo 5, imagem 1 %32
    • Using the PH0 screwdriver, remove the nine, 4mm screws on the bottom of the laptop.
    • You must remove the two, 4mm screws located under the battery. Remove the battery by following these steps: Asus G73JH-RBBX05 Battery Replacement
  6. Asus G73JH-RBBX05 Fan Replacement: passo 6, imagem 1 %32
    • Using a metal spudger, remove the back cover of the laptop.
    • Apply constant force in order to unhinged the panel.
  7. Asus G73JH-RBBX05 Fan Replacement: passo 7, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement: passo 7, imagem 2 %32
    • Remove the four, 4mm screws located on both of the hinges using the PH0 screwdriver and flip open the device.
    • Make sure you do this step for both the left and right hinges.
  8. Asus G73JH-RBBX05 Fan Replacement: passo 8, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement: passo 8, imagem 2 %32
    • Using a metal pry tool, remove the base cover
    • Once the cover is completely unhinged, don't forget to detach the strips connected to the motherboard.
  9. Asus G73JH-RBBX05 Fan Replacement: passo 9, imagem 1 %32 Asus G73JH-RBBX05 Fan Replacement: passo 9, imagem 2 %32 Asus G73JH-RBBX05 Fan Replacement: passo 9, imagem 3 %32
    • Locate the fan and remove the three 2mm screws with the PH0 screwdriver.
    • Before removing the fan, disconnect the cable.
Conclusão
3 outras pessoas executaram este guia.
Trevor Sprosty
Membro desde: 01/23/17
409 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 22-11, Maness Winter 2017 Membro de Cal Poly, Team 22-11, Maness Winter 2017
CPSU-MANESS-W17S22G11
Membros da 3
Autoria de 5 guias
Um comentário
Some steps missing, regarding screws to remove: 1 screw that holds optical drive; once that is removed, 2 screws in the drive compartment; 2 screws in the battery compartment; 3 screws from the bottom of the motherboard.
Byron Canfield - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,627
