Ir para o conteúdo principal
Asus G53JW-A1 Battery Replacement
  1. Asus G53JW-A1 Battery Replacement, Battery: passo 1, imagem 1 %32 Asus G53JW-A1 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Start with the laptop upside-down.
    • Turn the laptop so that the battery is facing you.
  2. Asus G53JW-A1 Battery Replacement: passo 2, imagem 1 %32 Asus G53JW-A1 Battery Replacement: passo 2, imagem 2 %32 Asus G53JW-A1 Battery Replacement: passo 2, imagem 3 %32
    • Look to the right of the battery for a small black switch.
    • Slide the right side switch to the right, away from the battery.
    • When the switch is in the correct position, a red sticker will be visible underneath the switch.
    • On the left side of the battery is another black switch. Slide this to the left, away from the battery, and hold it in place there.
    • The left side switch does not have a red sticker underneath.
    • Slide the battery towards yourself.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 229
