Ir para o conteúdo principal
Asus G501JW-BHI7N12 Trackpad Replacement
O que você precisa
  1. Asus G501JW-BHI7N12 Trackpad Replacement, Battery: passo 1, imagem 1 %32 Asus G501JW-BHI7N12 Trackpad Replacement, Battery: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Anti-Static Wrist Strap
    $7.95
    • Attach the clip of your anti-static wrist strap to the case of the laptop. This prevents any accidents that could fry the motherboard.
    • Remove the four 7.0mm Philips #0 screws around the battery.
    Pergunte ao FixBot
    Comentar
  2. Asus G501JW-BHI7N12 Trackpad Replacement: passo 2, imagem 1 %32
    • Unplug the connector highlighted in this picture by pulling it up and out of it's seating, then pull the battery away from the motherboard and remove the battery.
    Pergunte ao FixBot
    Comentar
  3. Asus G501JW-BHI7N12 Trackpad Replacement, Cooling Fan: passo 3, imagem 1 %32
    $7.95
    Pergunte ao FixBot
    Comentar
  4. Asus G501JW-BHI7N12 Trackpad Replacement: passo 4, imagem 1 %32
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
    Pergunte ao FixBot
    Comentar
  5. Asus G501JW-BHI7N12 Trackpad Replacement: passo 5, imagem 1 %32
    • Remove 4 pin connector from mother board.
    Pergunte ao FixBot
    Comentar
  6. Asus G501JW-BHI7N12 Trackpad Replacement: passo 6, imagem 1 %32
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
    Pergunte ao FixBot
    Comentar
  7. Asus G501JW-BHI7N12 Trackpad Replacement: passo 7, imagem 1 %32
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
    Pergunte ao FixBot
    Comentar
  8. Asus G501JW-BHI7N12 Trackpad Replacement, Motherboard: passo 8, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the six 5 mm screws located along the copper heat sink.
    Pergunte ao FixBot
    Comentar
  9. Asus G501JW-BHI7N12 Trackpad Replacement: passo 9, imagem 1 %32
    • Using the same Phillips #0 screwdriver, remove the nine 4 mm screws located around the motherboard.
    Pergunte ao FixBot
    Comentar
  10. Asus G501JW-BHI7N12 Trackpad Replacement: passo 10, imagem 1 %32
    • Gently remove the motherboard.
    Pergunte ao FixBot
    Comentar
  11. Asus G501JW-BHI7N12 Trackpad Replacement, Trackpad: passo 11, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the three 4 mm screws attached to the trackpad.
    Pergunte ao FixBot
    Comentar
  12. Asus G501JW-BHI7N12 Trackpad Replacement: passo 12, imagem 1 %32
    • Gently remove the trackpad from its slot.
    Pergunte ao FixBot
    Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 430
