Ir para o conteúdo principal
Asus G501JW-BHI7N12 Cooling Fan Replacement
O que você precisa
  1. Asus G501JW-BHI7N12 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
  2. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  3. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 3, imagem 1 %32
    • Remove 4 pin connector from mother board.
  4. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 4, imagem 1 %32
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  5. Asus G501JW-BHI7N12 Cooling Fan Replacement: passo 5, imagem 1 %32
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
Conclusão
Dustin Annis
Membro desde: 02/08/17
211 Reputação
Autoria de 2 guias
Equipe
UW Tacoma, Team 2-1, Rose Winter 2017 Membro de UW Tacoma, Team 2-1, Rose Winter 2017
UWT-ROSE-W17S2G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 2,025
