Introdução
The hard drive (HD) is where all your files are stored. Be sure you have a compatible hard drive when replacing it. Be very gentle when handling the hard drive, because any damage to the exterior may result in ruined data.
O que você precisa
Flip laptop face down and rotate so the battery is facing toward you.
To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
Slide the battery toward you and lift it out of the laptop.
With the laptop facing down, rotate it so the battery pack is facing away from you.
Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
Rotate the laptop 90 degrees towards you so that you are looking at the empty battery compartment.
Uma outra pessoa concluiu este guia.
