Ir para o conteúdo principal
Asus F555LA-AB31 Network Card Replacement
O que você precisa
  1. Asus F555LA-AB31 Network Card Replacement, CD Drive: passo 1, imagem 1 %32
    • Turn off and unplug the device before starting repairing.
    • Use the Phillips #0 screwdriver head to remove the ten 18mm Phillips #0 screws on the laptop's bottom.
  2. Asus F555LA-AB31 Network Card Replacement: passo 2, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 2, imagem 2 %32
    • Flip the laptop over and flip the screen up.
    • Pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
  3. Asus F555LA-AB31 Network Card Replacement: passo 3, imagem 1 %32
    • Disconnect the keyboard flex cable from its motherboard ZIF socket.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
  4. Asus F555LA-AB31 Network Card Replacement: passo 4, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to unscrew the one Phillips #0 screw that connects the CD drive to the motherboard.
    • Slowly slide out the CD drive, keeping it level, to remove it.
  5. Asus F555LA-AB31 Network Card Replacement, Hard Drive: passo 5, imagem 1 %32
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  6. Asus F555LA-AB31 Network Card Replacement: passo 6, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 6, imagem 2 %32 Asus F555LA-AB31 Network Card Replacement: passo 6, imagem 3 %32
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  7. Asus F555LA-AB31 Network Card Replacement: passo 7, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 7, imagem 2 %32 Asus F555LA-AB31 Network Card Replacement: passo 7, imagem 3 %32
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  8. Asus F555LA-AB31 Network Card Replacement: passo 8, imagem 1 %32
    • Disconnect the ZIF connector and lift the hard drive out of the space.
  9. Asus F555LA-AB31 Network Card Replacement, Battery: passo 9, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement, Battery: passo 9, imagem 2 %32
    • Remove the four 4 mm Phillips #0 screws securing the battery.
  10. Asus F555LA-AB31 Network Card Replacement: passo 10, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 10, imagem 2 %32
    • Lift up battery and remove it from the device.
  11. Asus F555LA-AB31 Network Card Replacement, Network Card: passo 11, imagem 1 %32
    • Disconnect the two wires connected to the network card.
  12. Asus F555LA-AB31 Network Card Replacement: passo 12, imagem 1 %32 Asus F555LA-AB31 Network Card Replacement: passo 12, imagem 2 %32 Asus F555LA-AB31 Network Card Replacement: passo 12, imagem 3 %32
    • Remove the seven Phillips #0 screws holding the motherboard down.
    • Lift the motherboard upwards, folding it towards the laptop chassis.
    • Unscrew the Phillips #0 screw holding down the network card, and slide it out.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 582
