Ir para o conteúdo principal
Asus F555LA-AB31 Hard Drive Replacement
O que você precisa
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: passo 2, imagem 1 %32 Asus F555LA-AB31 Hard Drive Replacement: passo 2, imagem 2 %32 Asus F555LA-AB31 Hard Drive Replacement: passo 2, imagem 3 %32
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: passo 3, imagem 1 %32 Asus F555LA-AB31 Hard Drive Replacement: passo 3, imagem 2 %32 Asus F555LA-AB31 Hard Drive Replacement: passo 3, imagem 3 %32
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: passo 4, imagem 1 %32
    • Disconnect the ZIF connector and lift the hard drive out of the space.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 25
Ao todo: 2,118
